Does anyone know if it's possible to buy a device to link up my Samsung LE40B554 to the internet, or is it only certain TVs that are able to do this? Thanks.
That's fantastic, thanks for that. I've had a look and it says you need a laptop or PC - is there anything similar that doesn't require this? Some of the newer Samsung TVs have something called internet@tv. With this I could stream directly from LoveFilm for example without the need of a computer...
I own the LE40B554 and i wasn't aware you could connect it to the internet , i will check the paperwork out tonight as its never been mentioned in any review, Also there isn't a connection for the internet
