Which Wireless/Bluetooth Headphones for the gym
stuwannop
HI everyone
First time poster and I'm looking for a bit of advice.
I'm looking to invest in a pair of bluetooth headphones specifically for use at the gym. I use the cross trainier, running machines and weights so they need to be quite snug. Charge times don't need to be the greatest as I'll only be there a couple of hours at a time and I will be using them from my Iphone 5. Budget is between £70 and £150 (ish!)
Any advice please?
Thanks in advance
Stu
Andy Clough said:
I'd be twempted to go for something like the Sennheiser MM 400-X - they're light, comfy to wear and fold up easily to go in your gym bag. You can get them for around £140-£150.
If you work out hard, headphones like that will be soaked with sweat - I know from bitter experience. You need in ear for the gym
I would agree, you will get too hot.
Get in-ears like the Audio-Technica CKX series instead. Little soft foam c-tip nestle comfortably in your ears.
