- Aug 10, 2019
- 2,556
- 4
- 0
Hi Guys, I was wondering if you could really really really help me. I got the new 250GB Xbox 360 for Xmas & I'm looking for a great TV to play it on. After intense research I have narrowed my choice down to these two - LG 32LS575T & Samsung UE32ES5500. Both retail for £349.99 at Curry's in the UK. Now... I will use the TV primarily for gaming, followed by watching movies & then watching HD TV.
1. Which TV (out of the two above) would you suggest is the best in terms of resolution, clarity, colours, refresh rate, hertz, sound & style? Which TV (out of the two above) would you recommend for stunning gaming & watching movies?
2. Which TV has the best Dynamic Contrast Ratio & Local Dimming?
3. The Samsung is also available in 40" & the LG in 42". Would it be better if I got a larger screen size instead of 32" for gaming? However, would this affect gaming in a negative way? For e.g. Slower refresh rate, lag, unclear image due to larger screen etc.
3. Other than the 2 TVs I have listed above, is there any TV you would recommend that is better overall? My budget is around £350.
Thank you soooooo much for your help.
Jai
Jai
