- Aug 10, 2019
- 2,556
- 5
- 0
Having had a weekend to compare my two amps I am now even more divided between the two.
Kandy K2 is a brilliant amp like the reviews say. Most acoustic/folk/jazz/electronic tracks sound amazing with it. The amp digs up detail across the entire frequency range and the soundstage is wide and spacious(no toe-in on the speakers).
The 7001Ki is a real champ, probably one of the best Marantz amps of late. It is not much behind the K2 as back to back test tracks showed. The Marantz is a tad more neutral and inoffensive - Roksan shows a tad more excitement and detail, both in bass and in higher frequencies. Differences between the amps are noticable but really tiny.
However, additional detail turns into a bit harsher rock music listening with K2, especially at higher volumes. I echo sewage man's experience as most rock recordings exhibit harshness - some brightness is present with 7001Ki as well (mostly due to poor recordings) but its somewhat amplified with K2 (hadn't really bothered me before with 7001Ki). I know this could be the fault of my speakers (MA RS6s) but after buying this amp and a new camera lens I can't afford a speaker upgrade/change anytime soon. My room has a lot of reflective surfaces (furniture, large sliding glass doors) which makes things a bit tough acoustically. I will be changing flats soon but at the moment this adds to the problem.
I have to decide whether to keep one amp or the other, and if keeping the K2, what to tweak to tame some of the brightness...
