Which Speakers ?
Hi All
I have a linn classik which may be coming to the end of it's life and may replace it with an Arcam solo mini or another step down to the Deno M 37.
My qustion is, is there some speakers that will compliment the Linn and if that goes then be good, and drive ok with the Arcam or Denon.
I'm thinking around MA RS 1's or B&W CM 1's or can anybody help with other candidates ?
Is it possible to have the Classik repaired or serviced? It's probably better than the alternatives you suggest.
Probably agree with Tarquinh if only for the puny power those micros have. Very efficient speakers, something like Kef's iQ7's would be a good starting point, available for around £300 now and a bargain. Great controlled bass too.
