Which optical cable for Sky HD??
grdunn123
293
6
18,895
Is it worth spending any money on an optical cable between Sky HD box and AV receiver? Currently using a cheap no name but what's everyone else using???
Cookie Monster
132
If you're Sky HD box is of the newer variety then you may have a coaxial output. Optical sounded a little 'limp' on my system. Cheap Coaxial cable made a great difference to the sound.
grdunn123
293
6
18,895
Hi Cookie Monster, you're right! Had my box replaced a few months back and it does have a coaxial input. Next obvious question then is......does coaxial sound better ( I think I know the answer to this) and if so is it worth investing a modest sum in a cable and, if so, which one???
chudleighpaul
129
You should be able to get a Coax cable from Maplin for about a tenner. Don't spend any more than that, you wont hear any difference.
fayeanddavid
191
professorhat:
chudleighpaul:Don't spend any more than that, you wont hear any difference.
Can you guarantee that?
+1
