Which one is better
lapuzrg
31
Hi experts. I'm currently in the Middle East (KSA) and with only a few audio retailers here. I plan to buy a decent stereo system in my room (4m X 5m, carpeted) I searched and auditioned the below mentioned kits. I listen to rock, acoustic, pop. Which one is better?
System 1 System 2 System 3
NAD326BEE Marantz PM6004 Marantz CR-502 (Old model)
MA BX2 Wharfedale Diamond 10.1
I intend to buy a Sony Blu ray player BDP-S370, which I will also use as a DVD/CD player.
Appreciate sharing your thoughts.
Have a nice day to all :)
lapuzrg
31
hortensio said:
for your music taste, I think system 1 would be the better choice.... :cheers:
Thanks for your advice, Hortensio. Much appreciated. :clap:
Cypher
156
System 1.
The marantz Pm6004 is a great amp but I don't like the Wharfedale speakers.
lapuzrg
31
Paul Hobbs said:
Why not try out the Marantz 6004 and the BX2? Are you limited to preset internet packages?
I will try to audition them as you suggested. Thanks for your advice. :)
lapuzrg
31
omnibeard said:
Surely if you auditioned them then you know which one was better?
My ears got confused after listening to those kits in a span of minutes.:grin: Thanks anyway.
lapuzrg
31
Cypher said:
System 1.
I am leaning towards the Marantz also. May I know the reason for not liking the Wharfedales?
Thanks again for your input. :)
Which is the best car? Audi, BMW or Mercedes?:) Depends on your personal taste, right?
Inter_Voice
62
If your choice cannot be changed then I would prefer System 1.
I would also suggest you to audition Marantz with BX2 they should also sound good.
ASK THE COMMUNITY
