Which IEM?
Hi All.
Thanks in advance for any replies🙂
My SA6s recently bit the dust and I need to replace them.
I like basey sound but need a mic and will be using Comply tips because I found them comfortable.
My budget is about £150 but i am now totally stuck having had so much differing advice. I can push to £200 if needs be...
What do I do??
Patrick
If that is your budget then I would recommend the Musical Fidelity EB50 balanced armature 'phones. Excellent
