Which forum members Hi Fi would you choose.
moon
47
If you had to choose. Which forum members Hi fi would you go for and why?
I would go for Jaxwired. Great room, nice simple system and the NAD looks the buisness.
CnoEvil
556
14
That's easy........Thaiman.
Ps. That means I'd also get to change it for more gorgeous sounding stuff every couple of months. :bounce:
CnoEvil
556
14
nopiano said:
I quite fancy Cno's gear, though might have to swap the KEFs for Sonus fabers!
You only think that! ;)
....but you might still be right (it would have to be the Amati Anniversario). :grin:
MajorFubar
690
6
If this means swapping without listening, probably no one's, because I might not like it, even if it's worth ten times more than mine.
But I seriously envy all the people with dedicated listening-rooms. I'd easy swap you my front room at the drop of a hat.
If I was going for a passive system it'd be either Cno's or Jaxwired's :)
tino
135
10
18,595
These bits of amcluesent systems :-
- Squeezebox Transporter
- Audio Analogue Maestro Settanta REV2.0
- Sonus Faber Guarneri Homage
- Quad FM434306
- Sonus Faber Concertinos
steve_1979
231
10
18,795
As I'd like a surround sound system it'd have to be either AlmaataKZ's or Winteracer's system.
AlmaataKZ has an all ATC 5.1 setup with SCM50A front speakers and a C4 sub.
Winteracer's AVI systems aren't actually setup for surround sound but they easily could be. I'd use his ADM40's as fronts, ADM9's as rears and the AVI sub to make a great 4.1 system.
