- Aug 10, 2019
- 2,556
- 4
- 0
Hello,
So after some research I think I am going to go with the Q Acoustics 2000 Series 5.1 Speakers and the Onkyo TX-SR608 amp for my new home cinema build.
Can anyone recommend a good Blu-ray player to go with this? Or recommend a different build?
Not very picky but I would like the option to play mkv files through the USB port and preferably have the USB port support NTFS hard disks so I don't have to convert the larger sized mkv files I have on my PC. Unless someone knows a good converter which doesn't jeopardize audio or video quality.
I was all set to buy the Cambridge Audio Azur 650BD Blu-ray player as I have heard some amazing reviews about it. However I read that it doesn't support NTFS hard disks and that 1 or 2 people have had problems playing mkv files (although this may be fixed in the latest firmware update).
Anyone have any suggestions or any advice?
Thanks!
Thanks!
