Which amp/speakers to buy
gillybrux
Hello there -
I am looking for advice on which (small) amp and speakers to buy.
I have an old (but I think good) turntable (Sansui SR-222MKII) and want to use it again for my long neglected vinyls. I am no connoisseur, and space is limited, but I do want reasonable quality. Budget up to £250 but not set in stone. Wireless speakers would be great but not essential.
I have thought of one of the new all-in-ones, but am thinking the quality will not be good...?
Thanks for any tips you can offer. gillian
stay away from all-in-ones. with this amount better check for second hand equipment, and be sure that the amp has a phone stage built in.
If your TT is old maybe you need to change the stylus as well
Denon PMA720AE with Wharfedale Diamond 9.1s. A great combination for close to your budget from Superfi.
You are right about your turntable - it is a good one. The SR222 models sit alongside the Pioneer PL12D as some of the best affordable decks of the 70s.
