P peterpan New member Oct 21, 2008 160 0 0 Jun 6, 2012 #1 I'm looking at the MF M3i and the Marantz Pearl Lite. I like a warmer sound without shrill highs or bright female voices (symfonic metal). Both amps seems nice. Have anyone heard these amps?
MUSICRAFT Well-known member Mar 23, 2009 2,675 1,095 22,570 Jun 6, 2012 #2 Hi peterpan You're on the right track with the M3i 🙂 All the best Rick @ Musicraft
Frank Harvey Well-known member Jun 27, 2008 567 1 18,890 Jun 6, 2012 #3 By the sounds of it, the M3i will suit your needs 🙂
P peterpan New member Oct 21, 2008 160 0 0 Jun 6, 2012 #4 Thanks for the answers 🙂 It seems the Marantz Pearl Lite is not so popular. My cdp is a marantz (6004). Will be the expensive MF m3cd worth to upgrade? Or better keep the Marantz and go for streaming? Anf then ftom MF?
Frank Harvey Well-known member Jun 27, 2008 567 1 18,890 Jun 6, 2012 #5 Keep the Marantz and go the streaming route. You'll not use your CD player much once you do.
P peterpan New member Oct 21, 2008 160 0 0 Jun 6, 2012 #6 Which streaming product is good with the MF m3i amp and the dynaudio x32?
O oldric_naubhoff New member Mar 11, 2011 23 1 0 Jun 6, 2012 #7 peterpan said: Which streaming product is good with the MF m3i amp and the dynaudio x32? Click to expand... MF M1Clic! of course. 🙂 (through tape out to bypass preamp in clic).
J jovend New member Oct 12, 2010 2 0 0 Jun 7, 2012 #8 I think a Densen B110... or better yet a B130 a worthwhile consideration for your xcite 🙂
