Clare Newsome:
QED already provide that info for
HDMI here on their website (I have linked to this numerous times).
But yes, a USB article could prove stimulating.
I have read the QED article. while it contains no incorrect statemetns, it does not actually say that hdmi (or any digital cable) affect sound/video quality. for example:
---------- As we speed up the skipping movement, the opening will begin to close, eventually coming to a point where it is no longer big enough to jump through. HDMI cables need this 'eye' to be open, so that it is easy to determine the difference between when the rope is 'up' and when it is 'down'. Increasing the speed of the digits and/or increasing the length of the cable, also reduces the size of the 'eye'. Measuring poorer quality cables already reveals they produce a smaller 'eye'. So, as the digit rate increases, the 'eye' of poorer cables gets smaller to the point where 'up' and 'down' are indistinguishable and the receiving equipment cannot understand the information (the digits) that are being sent. --------
does nto matter if the eye is small or big. the eye jsut need to be big enough - within the spec.
-----------------Real world variation and tolerances may mean that a cable produced to simply 'meet' the specification on paper, may not actually comply every time in production. Similarly, both electronic display and source equipment will experience some variation in production and may also suffer some degradation of their performances over time. This means it's not enough for a cable to merely meet the required specifications, it always needs to exceed them.
that is not a design issue. that is a quality assurance/quality control issue. there is no need to exceed the spec. a spec compliant cable of good workmaship will work all the time in the conditions it is designed to work in ovetr its design life.
Unfortunately, these are not the only factors that contribute to poor performance. Poor choice of materials, imprecise control of cable geometries during manufacture, as well as physical imperfections and construction tolerances are all sources of error which can degrade performance, even after the original design has been passed as adequate. ----------
that is not a design issue. that is a quality assurance/quality control issue. there is no need to exceed the spec. a spec compliant cable of good workmaship will work all the time in the conditions it is designed to work in over its design life.
------To use an analogy, if someone fires a gun at you, there are some who would argue that being missed by just one inch is exactly the same as being missed by a mile. However, when the gun is being fired as often as it is in an HDMI cable, and in addition, being fired from a hand that is shaking (however minutely) I personally would feel a lot happier if I was confident the bullet would miss by a mile!------
the analogy is good for explaining, but it is taken out of factual context. proper spec and desing would mean that the cable operates in the 'mile' zone, and not in the 'one inch' zone
-----What about the HDMI system's own ability to correct errors? QED's response to that question is simply: "Why introduce errors in the first place? Isn't it better to accurately receive every last detail of the uncompressed image, exactly as it was transmitted, instead of what the error correction thinks it should have been?"-------
again, having cable errors may or may not matter. if the system operates well above error-correction threashholds, it may not mattter at all. so this arguemtn needs to be quantitative to demonstrate anyhting.
so, the article does not say hdmi affects sound/image. it says that a cable has to be made well and implies that some headroom is desirable, without saying how much. marketing.
