Where can I get one of these.
I've tried eveywhere to get one of these, it's of a Yamaha reciever tuner to aerial lead, about 1m. Thanks all. I was going to put a photo on but can't. It's threaded at one end and co-ax aerial at the other.
its got a female thread the type the screws into the back of a dab tuner, and the other end of the 1 mtr cable a normal aerial plug.
Dave_
Mr Mucus:its got a female thread the type the screws into the back of a dab tuner, and the other end of the 1 mtr cable a normal aerial plug. Dab uses f connections as mentioned above , if your tuner has a female rather than a male, then use the lead linked to above by crocodile and an f to f coupler like this
Also available at maplin's here
basshound
116
daveh75:
Sorry to hi-jack the thread but I notice that you have a BK monolith Dave,what do you think of it,I`ve been considering the XLS300/PR
Crocodile
38
Not sure if you realised but the words in blue in my first post are links to what you want at Maplin. The ropey forum software ignored my attempts to underline for some reason.
Edit
Put the underline in manually.
Thanks very much crocodile, just ordered one from Maplin. Youu would'nt believe how much hassle i have had trying to get one of these, knowing what they are called helps, thanks very much again.
