Where can I get a remote control??
Hi, I have just got a Marantz PM4001 secondhand but didn't get a remote with it, I was just wondering if anybody knew where I could get the remote from? I have tried ebay UK and USA and they don't have any and I have also tried websites that specialise in remote controls but thy say that it will cost £120, I don't know about you, but I think that is just a bit off the prce they should be. Any help would be much appreciated. Thank you and Merry Christmas. :)
I'm sure any Marantz / Phillips remote should work - but your best bet is to get a cheap Universal Remote, like an All-In-One and use that for everything. With a Universal remote there will be a manual with a list of codes for each manufacturer, you type the relevant 4 digit code into the remote, and it'll control your CD / Amp whatever.
im using harmony 1000 remote to do every thing but must say not cheap around £180,works my sky box ,amp,360,projecter and dreambox 800
You may have tried this, but if not, you may find that a CDP remote from another brand will at least change the volume of the Marantz, which may be all you need (my Rega Solar does it, for example).
Hedgehog
Terryff
26
I have exactly the same scenario with my PM7200, but that one is only &0 quid, so not so bad. I understand with marantz remotes that they are all "system" remotes and should be relatively standard?
Either that or just get up to change the volume.ÿ
Tony_R
17
Terryff:
As I have to do with my elderly (but superb) Sony amp - didn't make 'em with remote control in those days!
Well not all of them lol.
Tony.
Hi, thank you all for your replies, they are much appreciated. I had dided to buy a new amp as I have just recieved a £500 bonus so there will be no need for a remote now.
