whats the best glue to reglue record covers?
rrm
23
got quite a few covers from older records( philips/DG esp) where the glue at the top/bottom seal has dried out and the cover now needs repair. Whats the best /easyist glue to use?
Hi-FiOutlaw
236
I use UHU paper stick glue from my son, it works like a charm. I apply with my finger and remove the eventual excess with a dump cloth, then 10 min under 10/15 records... et voilà
Hi-FiOutlaw
236
Al ears said:
I use the same but ,as yet, I don't know how long it lasts.
Mines are doing just fine...*i-m_so_happy*
*drinks*
thescarletpronster
10
I've used PVA glue (Copydex type) and even Pritt-stick with success. The covers don't need to be glued incredibly firmly, just held in place, so any type of glue should be strong enough.
