What TV?
Action-packed and thrusting existence measuring up the TV 😛oke: making phone calls to a couple of outlets to do a size comparison. As John said (thanks for that JD) 32" sets are about the same size as the old CRT.
Requirements (in no particular order): No wider than 80cm; adept at fast motion; budget £400 or less; must have at least 2 scart inputs; prefer HD tuner, although not essential.
A friend has a Phillips 32" and the clarity and detail is superb. Moreover the remote is one of the best I've seen on a TV; really solid, almost like Creeks. However the fast motion issue is a real let-down.
Suggestions welcome.
Ta, pp
John Duncan said:
(as are a lot of 32"ers)
Actually, scratch that - the first four I looked at in JL are all less than 80 🙂
In which case, I'd buy this:
http://www.johnlewis.com/231562834/Product.aspx
You'd have to see it for yourself to judge whether the motion thing is up to scratch though. I find mine (NX503) absolutely great on films but a bit rubbish on BBC HD for the football. YMMV.
You'll have to scrub that one as well John. (It only has 1 SCART andd PP needs two.)
[Edit] I haven't used SCART for years but - having just checked behind my Panasonic - it has two. Weird. Apart from VHS, I cannot remember what else they are used for. Old games consoles maybe?
All 32" TVs on John Lewis's website ( 23 in total ) have only one scart socket.
Finding a newish model with two may be problematic given that not much that you can buy now to plug into a TV uses a scart anymore.
Curses. I presumed it would have since mine does. Though 1 is better than - as I found out at the weekend whilst setting up a friend's Samsung - none. There was a weird 'external' socket that looked like a USB sort of thing and came with a USB adapter.
Let me have a dig on Richers...
Right, sorted. Just buy this:
http://www.richersounds.com/product/lcd-led-tvs/sony/bravia-kdl32ex713/sony-kdl32ex713
You won't get a better TV for £350. And you can save the £50 towards a bluray player to save you a SCART socket :-D
EDIT - 4* at £800...
And it has two SCART inputs. Perfick!
John Duncan said:
And 100hz, so probably better for football than mine.
Mine is so good with football (on BBC HD*) that I even watched some the other day. (And I really hate football.)
*Freeview HD is still a novelty as we have only had it for a couple of weeks in this area. Some BBC HD stuff seems better than Blu-ray! We watched 'Modern Spies' episode one just now (recorded in HD last night), and some of the aerial night-time shots over London had me convinced I could see window handles if I got close enough to the screen!
Thanks guys.
Funny little (and short) story. I phoned RS Kingston this afternoon and told him my exact requirements - as per my original post - and he said the only solution was to spend £500 plus on a Panasonic LED. Then when I mentioned a TV on their website he said: "Forgot about that one. Yes, that should do you fine, given your requirements." Don't expect miracles from anyone, but spend an extra 60 secs or so and he could've found the answer without any probing from me.
Certainly have a look at these over the coming days.
Most DVD players will have a HDMI output, if yours doesn't then you'll get one on eBay that does for about £20. So one scart is all you need.
chebby said:
It's a shame you didn't pick up a couple of those QED Performance HDMI cables from Tesco for £3.55 each last year...
Clicky.
I can say what I like about them because Max will find it impossible to argue that £3.55 was a rip-off 🙂
Sure he'll give it a good go...🙂
BTW, if I pay for the TV in full do you think they'll hold it for a couple of days? (pick-up Saturday) Just that I don't want to miss this chance but I've got find the best way of dispensing with the old'un. Also I'm also tied up wth work and the car is due into the garage tomorrow for a cambelt change.
