Vladimir said:
How do you explain the fact that people hear instant audible difference when they introduce a new component to a system sighted but need long term listening unsighted?
We need to dive into a theory of how brain acts in the process of creating music. Music is not out there in the air vibrating where science is king at putting numbers on it. Air vibration is not what people talk about or refer to as beeing music. Music is a product of perception processes in the brain. Like every emotion we have its non repeatable, contextual and greatly influenced by our mood. Take a walk alone in the forest and then you have a loud sound and get scared. Then as you walk along you perceive the shape of an animal. You react in immediate fear and focus all your attention on the shape. Getting closer you realize its only a shadow. When in fear we see things that are not there. Fear amplifies our perception. But look at this in this other way: If there really was to be a predator in those shadows, you would have seen it faster under fear. Knowledge can also amplify or reduce perception. The name 'naim' (example) will link to many expectations and alter slightly our mood. Perception beeing amplified music appears different too. At the point we explain ABX beeing the true. ABX = percetion of music an inner psychological process totally influenced by our mood, knowledge. I would just leave this part here with the small warning that if knowledge that there should be a difference affect us in seeing that difference, knowledge that there should be no difference can also affect us in seeing A and B as the same.
The most important part is the next one. Its the result of my own observations. I dont beleive in break in time very much (Well I do but so very slightly). I beleive it is mainly (like 80% just a guess) brain correction. I have many times tried amp switching and noticed that overtime they end beeing very similar while sounding very different at first. A bright speaker will sound very bright to someone coming from a dark one. But can feel dark to someone coming from a bright one. With cables the first time I biwired I was taken aback, just like every believers. It was just adding another cheap monster but god it was so different, so obvious. I tried to switch back hum I was not so convinced. I switched to bi-wire again and it was gone. Same thing with amps. I reaalized that the less I had been used to a component over a long period and the more I switched the less I would feel a difference. Overtime the component vanishes more and music end up sounding very normal. That is where ABX fails in that the brain adapts rather quickly and fixes things. When listening for a system for like 2 years the brain kinds of apply the sound patch. Switch to a component that does not need this brain correction and the brain at first still applys it and you get totally new sounds emerging and often plain oddness. This is my explanantion of break-in time. But also my explaination of the thousand of people litterally swearing to god that this amp/cable sounded soooooooo different. The brain is not passive, it created the music, its like imagination creating images. It also corrects faults, get used to exces and so to speak calibrates over time to a sound.
So I have those notions that im working on in order to explain the thruth with abx AND those thousands of people swearing that they had a clear perception of a clear difference. While you seem to be camped on one side right?
The way ABX should be done : put people for 7 days in room and play the same song over and over again. On the seventh day you give them a button to press when the song is played on the different cable.
My prediction is that they will all get it.
