What is the best Jack to Phone cable for £20-30?
Hello,
Just moved my setup around and due to this my current J2P cable isn't long enough to connect to my Mac :wall:
So i need a new cable looking for a fairly decent one around £20-30 with a length of 3-5m..
Cheers...
**** Phono i mean :type:
Is the QED Profile Stereo J2P a decent cable?
Big Chris
400
I'm sure the QED is a perfectly fine cable. I use an Atlas one, which sounds good and I would happily recommend it to you, but I'm not sure Atlas does one in the length you require.
Ordered a QED one seen it for £50 on most sites but amazon have it for £26 for 3m so not that bad....
