I'm contemplating getting a home cinema setup. I can only stretch to about £700 at this moment in time for the ampspeaker combo. I'm looking at getting a Denon 1910 with the Jamo A102HCS5 speakers. Eventually i would like to add an i-pod dock and possibly upgrade the speakers using the Jamos in a spare room. At this stage I only want speakers (L,R and Centre) that I can put on the TV stand
My questions are:
Do you think the JamoDenon combo will work? I've heard the Jamo's can sound too bright if not matched correctly.
Are there any other combo's that you recommend? The Sony STR- DH800 looks good but I'm not sure if i can hook up an ipod.
What sort of speaker cable would you recommend for this level system.
Any help would be greatly appreciated.
Pete
My questions are:
Pete
