what happen to my speaker
hi sir first timer..
i want to ask if what happen to my speaker because i used a wharfedale delta 50 with a 75 watts,using only a 2 channel with a sub i used this 2-way speaker in my Harman Kardon avr 145 after a 4 hour of playing music and when i look back i don't heared any sound in the left speaker..i switched it in the other side but still no sound as in nothing comes out..can you help me? did i blown-out this speaker,can it be repair and it will still be same as it is when repaired....
Do you mean that you put the speaker onto the other channel and it still didn't work? If that's the case then you may have blown either the speaker or the crossover - sorry!
As to repair, from memory the Delta 50s tend to be available on Ebay for next to nothing, and it may prove a lot cheaper to buy a used pair rather than get them repaired.
