Hi
i am getting a bit confused, ive been told to connect a DAC to my sonos ( a new project which i am laying cables for at the mo) in the living room which is going into an old NAD319 which has a marants cd sig and MS914, can some one rec a good dac at around £150 but most of all what connections will i need to go into the sonos & the NAD. Maybe honesty if it will actually improove things.
Also i am going to Pre Out the Nad to an AV so i can use the 914s as the music & front cinema sound, what would be the best connection type from the nad to the av ( most prob an LX82), & last but not least if you were hiding cables behind plaster board what cables would you run from the nad to the av cabinet just in case required, or am i being nostalgic with an amp which cost me money 10 years ago but i love !!!,
many thanks for the help
