what closed headphone for play clone hero on a drum kit?
djsolidsnake86
37
hello i need a closed hp, i bought a e-drumkit for play clone hero on pc, and i can't use my open headphones (i have a hd599 and a hd660s) because i hear the drumstick sound over the pads of the drumkit
so i need a closed headphones, important is the sound isolation and i prefer a neutral sound, what do you suggest me to buy? as amp i have a nfb 11.28, i don't search for something expensive, cos i just need for play that game or for some other things, but for listening music or watch movies i prefer the open headphones that i have
thanks in advance
Gray
Checkout AKG K550 - which are currently on the Mark 3 version.
I think they might suit your requirement well.
They're comfortable, not too clampy, but will isolate you from outside sounds.
Single-sided cable, so no twisting.
Best of all, they sound good - more like open-backs than you might expect.
Friesiansam
1,451
1,359
21,070
AKG K550 work best if the listener has a large head, so they clamp more firmly, otherwise they tend to be light on bass. I've a big head, so they work well for me.
