ontheline said:
ontheline said:do you think this would do the trick? http://www.amazon.co.uk/dp/B00B7KR492?psc=1
ontheline said:thanks again for your help with this but i'm still confused as reading the review it mentions USB "USB means you can stream from a laptop" how do i stream using USB for the best sound quality. no disrespect but it doesn't mention anything about a toslik cable. i am simply looking to find out how i stream music directly from my USB socket on my imac. i don't want to be buying unnecessary cables if it's more simpler with using USB.
THIS IS THE SECTION of the review from what hi fi mentioning USB. i just don't understand what i need in order to do this and is it just a case of simply connecting 1 cable from imac to zeppelin.
The USB input fitted to the Zeppelin Air is used for firmare updates – and you can now sync a docked iPod or iPhone. You can also stream music directly from your laptop’s USB socket.
Of all the listening methods, we found this to give the very best sound quality, just edging out a docked iPod/iPhone in terms of dynamics and detail.
Read more at http://www.whathifi.com/bw/zeppelin-air/review#X1Kmco9BxyJZmIEV.99
Gazzip said:If you are trying to keep the audio out socket free on your laptop for some reason then you could output via USB in to an SPDIF converter and go in through the Aux Input on your Zep.
chebby said:I'm out of this one.
One lead is all you need. (USB or optical).
Good luck with all the extra convertors/boxes etc. if you decide to go down that road. (Really no need.)
I suspect the Zeppelin Air is not the right device for you.
unsleepable said:AirPlay should be the easiest option. Just make sure that the Zeppelin is configured for your network, and select it as output device in your computer.
Audio resolution through AirPlay is limited to 44.1KHz/16-bit, though, and since you mentioned hi-res music you will have to go with USB or optical. I would try USB first—probably, you already have a cable you can use. Open Audio MIDI Setup from Application/Utilities and see if you can select 96KHz/24-bit as audio resolution.
An advantage of plugging the speakers on the USB port instead of optical is that, depending on the software, you can play music through the Zeppelin and still get the OS ding-dongs on your computer speakers. This can be done with AirPlay, too.
ontheline said:that is the problem i don't have any USB cable and don't know which one i need?
