what are your thoughts on...
tcooper
10
B&W 805 front
B&W xt2 rear ( or 805 ?? )
B&W pv1 sub
B&W xtc
and DENON avr-4810
It taken me two weeks to chose Hope you agree but please advice
Thank you
What made you choose that receiver? Are you going to use multiroom? Do you really need the 11.3 spec?
If not you will be better off choosing something else. I would be looking at spending half of the budget of that Denon 4810 on a stereo amp, and get an AV receiver with the other half... If you must have a one box solution, I suggest looking at something like a Yam Z11 or Z7.
It will be no multiroom. This is my sitting room 5.1 system only.( Would it sound better if i was to have two subs?)
I only want clear sharp sound. What do you mean by one box solution?
I was thinking insted of blu ray to buy multimedia with built in blu-ray ?
Thank again
By "one box" I meant one AV amplifier.
To do justice to your choice of fronts I recommend a good stereo amp and a multichannel AV amp though (so two boxes). If you don't like the idea of two amps, get a very good multichannel, like the Yamahas I suggested (rather than that Denon 4810).
How do you find the 805's as fronts, do they sound as good as they look? Are they the new version or the model that has just finished?
