What are the best settings For connecting ps3 to onkyo txsr 875
pip1st74
24
Im having problems with the sound qualite on they on blueray from my ps3.The ps3 is connected to a onkyo txsr 875 amp,I see on the what hi-fi speck list that the ps3 should be able to send out True HD & DTS HD if this is so why does it not come through my amp in that format It never changes from the all channel out. What am i doin wrong,Any ideas ?
Paul
Lost Angeles
130
I'm no expert on this (I'm not even a gamer) you need someone like Professorhat to answer this but I think he answered this before and you need to send the signal in bitstream from the PS3.
By bumping this back to the top of the list you might get someone who knows to answer.
margetti
134
You might be lacking replies as this is posted in the wrong section...
Same question was asked only a day or so ago - answer copied and pasted:
The PS3 can't bitstream HD audio, so you will never see your amp displaying the HD lights on the front.ÿ It has to decode internally and output as LPCM.ÿ As long as your PS3 is setup as follows you're getting HD audio.ÿ It does sound like your setup is correct but to recap:
On the PS3 select sound settings
Select HDMI
Select AUTO
Check that all the Dolby Digital, DTS and all the PCM boxes are ticked (inc. 7.1)
Save
Go to the BD/DVD settings
Select PCM as the audio setting and again save
ÿ
That
should be it.ÿ Set your amp to auto and ensure you select the HD audio
track in the menu and you can see which audio format is being played by
pressing the display button during playback.ÿ
