Hi all,
Im a complete novice to all this, but my dilemma is that im not sure what amp should go with my JBL ES100's?
Ive just blown a tweeter in one of them, which ill hopefully be able to repair by buying spares. I also saw somewhere that an underpowered amp could blow the tweeters? The amp i currently have is a cheap and cheerful eltax AVR-800 6.1 channel (6 x 92w)
it is currently bridged and biwired to the speakers, but im thinking the speakers are under powered......?
JBL ES100 specs
Frequency response (–3dB): 32Hz – 40kHz
Max. recommended amplifier power*: 250W
Power handling (continuous/peak): 125W/500W
Sensitivity (2.83V/1m): 91dB
Nominal impedance: 8 Ohms
Crossover frequencies: 450Hz, 3000Hz – 24dB/octave; 12000Hz – 18dB/octave
Low-frequency transducer: Dual 250mm (10") PolyPlas, shielded
Midrange transducer: 100mm (4") PolyPlas, shielded
High-frequency transducer: 19mm (3/4") Titanium-laminate dome, shielded; EOS waveguide
Ultrahigh-frequency transducer: 19mm (3/4") Polyester-film, ring-radiator, shielded; EOS waveguide
Dimensions with grille (H x W x D): 1149mm x 305mm x 422mm (45-1/4" x 12" x 16-5/8")
Weight per speaker: 29kg (63.9 lb)
*i also need the amplifier to have hdmi input/output for ps3, sky hd etc*
any advice would be greatly appreciated, my budget is approx £300.
Regards,
Matt
JBL ES100 specs
Regards,
Matt
