- Aug 10, 2019
- 2,556
- 4
- 0
G'day guys, I've recently downgraded my fronts from the superb Diamond 9.6 to Diamond 9.1 . Yeap that's a massive downgrade alright but honestly I'm enjoying the current 9.1/9CM/9.1 more then the 9.6/9CM/9.1 setup in my moderate sized living. With the 9.1 at the front, everything seems to be much more defined and I can just feel perfect phase coherence . But then there seems to be a big hole in the soundstange with the 9.1 and the bass weight and midbass snap are just not adequate even though I've got them crossed at 80Hz via the receiver. In this scenario would I notice an improvement going a step up to the 10.2 or 9.2 or even the 10.1 and would it make any difference in overall bass and mid-bass performance ? I intend to high-pass them at 80Hz. There aren't any reviews on the 9.2 or the 10.2 . Are these speakers similar to the their .1 brother but with the added advantage that comes with a larger cone size ? On the other hand , my local dealer suggested the PSB Image B6 setup. I haven't had the oppurtunity to visit him for a demo yet but does anyone know if the Image setup is better then the Wharfadale setup ? The suggestions would be much appreciated fellas Cheers,Amuth
