I already have the dentons. They are exceptional speaker in terms of sound and build quality. I happen to see a MA RX1 in piano black gloss, lovely speakers too. How was it compared to dentons? Anybody heard both? Inputs please
plastic penguin said:I'm a big fan of the 1970s Dentons...
chebby said:plastic penguin said:I'm a big fan of the 1970s Dentons...
Not sure if the OP is referring to the current model Dentons or the original 1960s Dentons or the 1970s 2XP versions.
plastic penguin said:As you know no-one else had responded to the OP's question I recommended he try and listen to the MAs before committing.
floyd droid said:plastic penguin said:As you know no-one else had responded to the OP's question I recommended he try and listen to the MAs before committing.
Committing what , suicide ?.
floyd droid said:I know I know PP. It didnt read right but I couldnt be fagged to delete it ,lol. Bored today ,does it show.
Mibbe I should have typed ... suicide after being subjected to.....
floyd droid said:Have they sorted your frisser spinner yet PP ?.
danrv said:Used to own them. Smooth, controlled sound with a slightly rounded off treble. Would liked to have kept them but bass was a little too much as I had them in corners.Went for front ported instead.
Very nice speakers in the right setup.
manicm said:danrv said:Used to own them. Smooth, controlled sound with a slightly rounded off treble. Would liked to have kept them but bass was a little too much as I had them in corners.Went for front ported instead.
Even a front-ported speaker is going to be compromised right in a corner. Mine are not right in corners but about 20cm from the rear wall. They're smooth but I don't find the treble rounded -off. In fact they're more extended than the BX2.
Or a nad 326 for the rx1Bebeboy said:I mean the new dentons, 80th anniversary edition. They are easy on the ears. Would the rx1 also pair nicely with a rotel rc1550 preamp and rb1080 power amp, cd player is a denon dcd 1650al and rotel rcd 06se. Chord ics and speaker cables.
or a nad amp say 325 would be better paired with the rx1?
thanks mates
Bebeboy said:They are stunning on high gloss black mates.
danrv said:Bebeboy said:They are stunning on high gloss black mates.
I bet they are. I had the rosewood real veneer finish.
Enjoy your new RX1's!
Bebeboy said:I already bought the RX1. I am very impressed so far to say the least. Bass is powerful but controlled. High and mid is very very impressive. They are stunning on high gloss black mates.
