weak signal
Have a hd box with 30 meter cable run, 40% signal strength 40% signal quality can i fit a booster to improve this.
daveh75
727
137
19,070
What sort of HD box........ SKY, freesat! Also has it alway's been this low or just gone like it recently and i assume your having picture/sound problems
sky hd , weather effects picture sometimes and quite often says no signal being received always been like it
daveh75
727
137
19,070
There could be numerous reason's for this,for example
have you got a clear line of site i,e dish not obscured by tree's,building's e.t.c
Sub-standard cable could have been used,
Dish maybe slightly mis-aligned,
ETC,etc,etc
But as it's been like it since installation, i suspect the dish is mis-aligned....it only has to be marginally out to cause low signal. I'd get sky back to check it out.
FWIW no you can't just add a readily available signal booster like what is used for terrestrial aerial's to improve signal.You can get Satellite specific in-line and powered amplifier's but not really intended/or needed for standard Sky installation's. As i said above get sky back!
Would use ct125 cable rather than ct100 on that run length.
Less signal loss.
