Watching BBC I-player overseas
Hi - apologies if this is in the wrong forum, but I have a question regarding watching i-player overseas. Basically a friend of mine has gone to live overseas for a few months and is distraught at the prospect of missing Strictly Come Dancing! She's tried to log in to i-player but it tells her she can't as she's not in the UK - is there a way to get round this?
Many thanks in advance for any advice
My understanding is that I-Player is configured to only allow UK based IP addresses to access the service. BBC programmes are only cleared (and therefore available) for the UK. Other broadcasters may well have paid to screen a particular show in their territory and I-Player being available world-wide would breach those agreements. In addition, agreements with the talent unions will restrict viewer access to the UK.
You'll have to tape it for her and send it off.... or there's U-tube, if she's quick.
Ravey Gravey Davy
225
If there is a relative or friend in the UK who will let them have access to their pc network you could use something like winVNC remote access onto their pc and then watch it remotely through that.
John Duncan
2,033
27
19,720
Can somebody explain this to me? Does it mean if I plug this into the back of my telly I can watch it on a PC anywhere in the house (or anywhere there is an internet connection)?
Clare Newsome
1,657
JohnDuncan:Can somebody explain this to me? Does it mean if I plug this into the back of my telly I can watch it on a PC anywhere in the house (or anywhere there is an internet connection)?
Yep. Slingbox rocks.
You can even change channels via an on-screen replica of your remote control. Warning, however: this can freak out people also watching said system in the main room.
Andrew Everard
1,878
Exactly. This did the same thing, but I think it's discontinued now.
Ravey Gravey Davy
225
Yes but you have to connect it to your router as well as the TV .
John Duncan
2,033
27
19,720
Ravey Gravey Davy:
Which is sitting on top of my Virgin STB
Ravey Gravey Davy
225
JohnDuncan:Ravey Gravey Davy:
I am jealous.
Mine is in the diametrically opposite corner of the house with a tiled/concrete floor.Hardwiring it to the front room is "on the list" to do which will probably be catalysed by the arrival of the Humax Freesat PVR if it is any good.
John Duncan
2,033
27
19,720
Ravey Gravey Davy:JohnDuncan:Ravey Gravey Davy:
I am jealous.
Couldn't you just connect it to a wireless access point of some sort? Like an airport express even? Or does it need to be connected to the router directly (can;t see why that would be case)?
Christmas is so sorted btw.
Ravey Gravey Davy
225
JohnDuncan:Ravey Gravey Davy:JohnDuncan:Ravey Gravey Davy:
I am jealous.
Couldn't you just connect it to a wireless access point of some sort? Like an airport express even? Or does it need to be connected to the router directly (can;t see why that would be case)? Christmas is so sorted btw.
Sorry John,I posted a quick reply to this but it seems to have disappeared or not got posted.House is very wifi unfriendly.Damned Victorians thought of everything but wire free accessabilty.There are so many wireless gadgets of the kids hogging the wireless network I am going to hardwire the front room so the parents come first on the good signal list,be it blu ray ,laptop or whatever.I am going to have to drag it all out of the corner to get the freesat cable in so it should not be an issue to do that at the same time.
Xmas is also sorted or so the wife tells me.Apart from 14 for lunch on the 25th.-which is my problem- stuff the presents (rather than the turkey)
