- Aug 10, 2019
- 2,556
- 4
- 0
Hi All,
Just wondering if there is any benefit of ceiling over wall mounts for a projector?
I’m planning to turn my sofa in the living room through 90 degrees as it will give more usable floor space (no sniggering at the back, i mean for a coffee table etc). This means the projector can no longer sit on the shelving where it currently lives.
As I see it the wall mount would be easier to fit, and I’m not limited to picking a drop of X cm (even if it is adjustable to some extent) which may not be suitable for my next home. However, I’ve always associated mounted projectors with being on the ceiling. Is there a reason most folks take this option?
Thanks for any advice.
Ed
Ed
