Ravey Gravey Davy
225
I have been instucted to find out how to get the vinyl onto CD.
My deck has built in phono so is plugged directly into my Onkyo 606.
Can I use the zone 2 rca out to usb on the laptop??? with one of these
Edit- laptop also has 3.5 micophone input but this is described as monaural input.
What is the best free software to use.
Ta.
I don't know anything about it but is this any help?
Edit - sorry just seen that Superpack thing has been discontinued.
DistortedVision
228
47
18,820
You need a dedicated soundcard to do a semi decent job, do you have a desktop PC as well as a laptop? If so something like the M Audio 2496, which is a PCI card, is probably the cheapest card available that will give decent results. Otherwise, if you've only got a laptop you'll need a usb card and you'll need to spend a bit more to get good results.
I use a M-Audio Delta 66 and rip with Soundforge, although that software isn't officially free.
Another alternative would be to get a usb turntable and connect it directly to your laptop. I think you can pick them up for under a £100, although I suspect they're gonna sound terrible.
Ravey Gravey Davy
225
Thanks for the replies- I have now come to the conclusion that the laptop isnt up to it. I am going to check out the sound card in a spare pc I can put my hands on and try the free software through that.It is for a relatively low key use in the car so I will not be spending bucket loads on it.£7 for a cable as a gamble is worth it.(unless I should be buying a £50 one
chebby
1,253
26
19,220
NAD PP3 (£75)
http://nadelectronics.com/products/hifi-amplifiers/PP-3-Digital-Phono-Preamplifier
It is a traditional MM/MC phonostage which also includes an Analogue-digital-convertor that you can plug straight into your computer with USB. (16 bit 48khz)
It includes 'Vinyl lite' software.
Project Audio also make a very similar product for about £85...
http://www.project-audio.com/main.php?prod=phonoboxusb&cat=boxes&lang=en
You can try Audacity software (free) for ripping files from vinyl (or cassette even)...
http://audacity.sourceforge.net/
