vibration isolators
In the recent discussion concerning vibration someone suggested using squash balls cut in half as vibration isolators. Does anyone else have experience with that method?
Ketan Bharadia
44
As a cost-effective way of getting some isolation for your kit it works well. Though I have to say a dedicated platform like Audiophile Base's Base 01 (around £140) will work better. But, given the price difference that's no surprise.
Gerrardasnails
295
Why use squash balls unless you play and have them lying around. Check these out http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230205165341 not a great deal of money and will probably be a little better than cutting squash balls.
I had a noisy Humax PVR, I stood it on some pieces of foam packing I got from B&W when I needed to replace a tweeter which had become damaged from a digit of a small child
The new tweeter works fine and the packing it came in is now under the Humax and it sorted out the vibration problem, 2 jobs sorted in one.
BTW many thanks to B&W, I ordered the High frequency unit over the phone and it arrived the next day, excellent service.
Thaiman
360
[quote user="allon"]In the recent discussion concerning vibration someone suggested using squash balls cut in half as vibration isolators.
Does anyone else have experience with that method?[/quote]
I think it's an old wife's tales myself but acknowledge that at least one of my HiFi friend is using this method.
This shop has some bargains - (I'm not affiliated by the way) - the spikes I bought for my CD player worked a treat for me...........
http://stores.ebay.co.uk/The-Solid-Shop
Also, some spike shoes work for me under speakers - tightened up vibration/bass effectively.
