VDH HDMI Flat vs.Chord Company Supershield HDMI
hi all,
I know VDH is a little bit pricier but is it much better? Chord just won Product of the year award (I think like VDH last year). I am about to buy some now. Should I spend a little bit more and go for the VDH or there is no need for that and Chord is as good for less?
Thanks,
stone28
Others may disagree but I doubt you would notice any difference between the two. You can't really go wrong with Chord. Like buying IBM in the 1970's. Both are good cables. Buy either with confidence.
barnsleydave:Others may disagree but I doubt you would notice any difference between the two. You can't really go wrong with Chord. Like buying IBM in the 1970's. Both are good cables. Buy either with confidence.
I don't
Do a true blind test you wont notice a difference ( and I didn't mean wear a blinfold
