my little dot has a soft glow but I have seen pictures of other little dots and the valves are quite bright - does the glow give you signs of the valves overall health? just curious and yes I have nothing better to do on my day off!
Well I'm going to be off in a bit to get the car MOT'd and finishing other tasks so not much time to listen to loads of tracks I've noticed the little tubes on the mk3 are clear on top - half clear and half silver coated...is there anything wrong with them...? Does anyone know?
You need not worry - the silver stuff will change white if air has entered the envelope indicating a dead valve, the placement doesn't matter. This only happens if it has been under mechanical stress, if say, the tip had been snapped off.
The construction of valves varies between different manufacturers so the glow will be different, some have covered heaters for example so you see very little at all. Also don't forget that some pictures are taken with a long exposure in a dark room.
