You can get more power out of two tubes than one. You may be surprised to learn that you can get more than twice the power out of two tubes in push-pull then you can get out of just one. In simple terms it's like two people cranking a human powered winch. There are two cranks, one on each side of the winch. The two cranks are 180 degrees apart and just when one man gets to that part of the circle where he is lifting and pushing away on the crank (his weakest point) the other man is pulling down and toward himself (his strongest point). It works much the same way with two tubes in push-pull. They are working 180 degrees apart and when one tube is in a condition where it is making the weakest contribution to the power the other tube is at its strongest.
