jala: Hi,
I would like to buy some speakers for my laptop that connect via USB and are wireless. Are there many speakers like this and if so could you recommend any?
Couple of years ago, I bought a 2.1 system online. I think the etailer was Aria or Avia Shop or something approaching (based in Greater Manchester, IIRC). The brand was "Ozaki" which I had never heard of. The sound was "adequate" for a wireless system in those days (circa 2005-2006). Certainly nothing close to being 'hi-fi'. I still have the system in storage and it'd be interesting how it sounds reproducing FLAC files for instance. Back then I was happy with my 128-192Kbps MP3 files in iTunes. I'm not sure I want to recommend or steer you away from this "Ozaki" system but the solution exists. I couldn't tell if you'll like the sound of it.
