- Aug 10, 2019
- 2,556
- 4
- 0
I have a Project Debut 2 turntable, about 8 years old now. I sometimes get annoying harshness of records where it sounds thin, and slightly distorted. happens on some records more than others.
I have an Ortofon OM5e cartridge.
Anyway, I'm wondering what my options are. Can I change the stylus/cartridge? I've heard I can put an OM10 stylus in the exisitng cartridge, or a OM2 red cartridge?
The debut 2 is pretty limited: there is no adjustable tracking weight thing, but it does have a weight that hangs on a string...
Any help/advice on this would be very much appreciated!
Thanks!
Chris.
Thanks!
Chris.
