I'd be interested in upgrading my Sky installation. To do so I think I would need an upgraded LNB unit like this?
http://www.satellitesuperstore.com/skylnb.htm#titaniumskyquatro
Any other suggestions?
I could also upgrade the cable with something like these -
http://www.futureshop.co.uk/advanced_search_result.php?search_in_description=1&keywords=lnb&categories_id=&Go=Go
Russ Andrews also do V20 Coax cable.
Is it F-connector to F-connector I would need?
Would doing the above make a sizeable difference?
On a related note, you can spend thousands on blu-ray players etc, but no-one has brought out a premium Sky box. Would this be because Sky license the technology or that they dont want too many different manufacturers making boxes that may give technical problems down the line, for instance upgrading the EPG?
