upgrade??
wilmot
Hi I currently have the following set up-nad c545bee nad c355bee MA RS 6 speakers. Would i notice an inproved sound changing the amp for Roksan k2 and the speakers for kef Ls50 or i'm i better off sticking with what I have got
KidKomet
18
See if a local dealer has the stock for an audition or even better, a home demo. I'd say definitely a difference but whether you'll think it's improved is yet unknown. I'm given to understand those KEF's require a really solid amp to get the most out of and I've not heard them with the Roksan, I imagine it'd be a good match though.
BigH
97
I heard the LS50s I think they need a good powerful amp and not so good at low volumes and need a bit of space. You may want to consider the KEF R100s. Try some at a dealer and see what yo think. IMO speakers are the most important item.
plastic penguin
1,673
120
19,870
FWIW the Nad, although a good amp, can be bettered. There are others that give a more balanced tonal presence and are more transparent. The Kandy K2 is a good call, as is Creek, Audio Analogue. I know from experience Monitor Audio Silver range needs really good amplfication. Not because they're difficult to drive but they just bristle with high quality amps.
g777o
10
Mine seem to be OK at lower volumes, its just that they sound so good, so you want to crank them up at every given opportunity :rockout:
plastic penguin
1,673
120
19,870
stevebrock said:
plastic penguin said:
stevebrock said:
Maybe your lovely Naim CDP could do with a nice brushed finish........you might love it more!
Wouldn't change the CDP for some time. It is what it is...
a thing of beauty I think, but pig-ugly next to Leema
Beauty? Nah. More the case of average looks alongside a amp with average looks = hideous.
ASK THE COMMUNITY
