Hi there I think it,s about time i upgraded my system,some hints please. Budget £2500 Meridian 506 cd Audiolab 8000a amp Mission 753 speakers
Thaiman
360
yeb, the audiolab and Meridian combo seem to be lacking that excitement needed in midrange system. If you meridian is a 24 bit version I would keep it and replace your 8000a with Densen B110 or Creek Destiny. (around £1200) As I don't know your taste in music the 2 amps I sugest are quite an all rounder, will play most music without fuss.
I'd say the speakers then the amp are the ones to upgrade first. The 506 is a classic. Don't know about the audiolab. If you can replace both the amp and the speakers in one go, that will make it easier to audition - just use a meridian dealer such as KJ West One if you're in london. If you like acoustic music, try sugden amps for gorgeous, lush, clean sound.
Thank,s to you both,will check out Sugden amps,now what speakers.
All the best for New Year and thanks again.
