yesterday i finally had time to take my Pioneer A400 apart and try to fix some minor quibles i had been having and to give it a spring clean - and boy am i reaping the rewards now! I now have what sounds like a new amp with a now 3D soundstage, improved detail, better seperation, imaging and and a sense of more space! Plus i also fixed the problems i had been having: sometimes when i powered it up it wouldnt balance properly and also there was a slight crackling when i adjusted the volume. After unplugging it from the mains and removing the top half of the case i took to it with a soft paintbrush and vacuum cleaner. after removing all the dust i could see i sprayed Caig DeOxit contact cleaner on all the switches, pots, contact points and pieces of copper wire i could see. I then sprayed more Caig over the entire PCB and used the paintbrush to clean it. I left the amp for 1 hr to let all the cleaner evaporate before putting it all back together. No more crackling, no more balance issues and boy oh boy it sounds phenomenal! it is as if i have upgraded my cdp. so my advice to you is if you have a some spare time soon get cleaning and prepare to be amazed!
