Upgrade Arcam AV50
As you can tell by the subject name, my kit is rather old - but I love it!
I have an Arcam 8SE CD player, an Arcam AV50 surround amp and an Arcam 8P power amp. These are bi-amping a pair of B&W 603, there is a B&W CC6 centre speaker and a pair of B&W DS6 at the rear. All very nicely sounding and pretty desirable - back in 1998 when I bought them!
My DVD player is a Sony DVPS-735, this handles all the digital processing as the Arcam AV50 does not have a digital decoder, but has a set of 5.1 analogue inputs. I would like to make use of another digital source - a Sky+ box to my system, it is currently connected via interconnects. Are there any suitable digital surround processors that I can add to my existing components?
Dave
Processors don't come that cheaply, so it depends on how much you are prepared to spend. The Audiolab 8000AV can be had for about £700 from Superfi, and would do what you want.
You might be better off just buying a much newer integrated AV amp that does all the processing and will have more connection options than you could possibly need.
