Up Grading Equipment
Help! I have Alpha 9's power amp. & CD player. My speakers are Mission 762F. I am concidering a change & don't know where to start. I don't want to stay with Arcam anymore. I'm open to any suggestions. I like a "warm" sound if that makes any sence.
Bump!
I realise my original question is a bit vague but I would appreciate any recommendations or advice. I am not as up to date as I used to be when I originally bought my arcams back in 1997. I am willing money. Thanks!
Hi Spogger
Can you give details of your maximum budget, the size of your room and the type of music you like.
This would make it easier to get the ball rolling.
Thank you Room is 4 1/2 x4 mtrs. budget €1,5oo/2,ooo .I like listening to acouist and some times loud rock
Thank you. All problems with Arcam had to do with build quality.For the first 3 or 4 years the cd. player went on vacation and just stopped playing. Many rows, eventually returned to manufacturer,sounding good since.
Lots of problems with the amp. over the years. Selector sw.(cd. av. aux. etc.) packed up, amps. went on one channel volume controll must be turned up to 20 to before both channels kick in, now selector sw. acting up again.I might be forgeting other things I try hard to.
Thank you very much for your help, I will check out that gear.
