the record spot:78finn:
But obviously when putting together any hi end phono system you need to make sure that most of your budget goes on an unbelievably good amplifier/speaker setup.
The OP has £2k to spend on the t/t and no, he doesn't need to spend the full amount, but that's all he has to spend for, there's not amp or speaker set-up to consider as it's already there. But are you saying that out of a total budget of (say) £2k, you'd spend £500 on a P3-24, then the remainder on amp and speakers?
I think for a vinyl based set-up, the greater individual proportion would go on the deck; 40%-30%-30% for instance. It's the most important component, it provides the information from which everything else is built round.
I can see a slightly bigger proportion on a digital going on the amp, but not with vinyl. Perhaps not so obvious after all...?!
No, that's not what I was saying at all!? I was saying that he should maybe consider buying a cheaper turntable - obviously keeping what he already has re: speakers, amp etc. I then suggested that he spend the rest on a good separate Phono Amp/stage. You can get a great phono amp/stage for about 500 these days. So that would still leave about 500 in change. And that's all I was saying. At this price point (1500 top) I think the Rega 3 is still up there, especially when twinned with a good cart.
I certainly never suggested that he change his entire system on a budget of 2K!???? Not sure where you got that from. I made no suggestions of amps or speakers? I was trying to point out that he maybe better of spending substantially less on a turntable and then pointed out that it's the supporting components of his system that will shape the sound anyway i.e. the amp and speakers. No point spending $1500 on a turntable otherwise.
