On the spur of the moment I bought an Akai AP-B20C turntable from a car boot for £20 at the weekend. Got it home cleaned it up and it works a treat! However I noticed that the speaker drivers sort of bounce around quite a bit, in and out as the volume is eased up but not to loud, so I don't think it's feedback from the deck. Obviously feedback does kick in at louder levels of volume. The speaker problem doesn't happen when say the same music is played from Spotify.
It had a Technics 270C cartridge fitted which seemed to have quite an acute needle rake angle which I thought may be the problem, so I ordered an Audio Technica AT95E (recommended) which came today. After fitting the new cartridge it's still the same though the needle angle now seems correct.
The speakers are B&W 602's with a Yamaha RN500 to which the deck is plugged into the phono stage.
Any help much appreciated.
