Hello all.
For Fathers' Day my wonderful daughters collected together various old bits of hi-fi I had lying in storage around the house and assembled them all in our front room so I could have somewhere to listen to music, like I used to as a teenager.
Despite being initially overjoyed, it quickly became apparent that my Goldring GR1 turntable had speed problems so I decided to treat myself to a modern, entry-ish level turntable.
I almost bought a Rega RP1 Performance until I saw a photo of the motor mount, which was essentially Sellotape. That build issue alone sent me to the Pro-Ject Debut Carbon.
I am generally pretty pleased with the Debut but, I notice there is a sort of rumble or something in the silence between tracks. It is really distracting and on headphones it is almost maddening. Here is a recording of it straight out of my amp into my laptop.
https://copy.com/7n2zy6B1nTNCjFA9
Any utter silence you hear is the actual output of the Pro-Ject Carbon with its stylus in the air. Then the stylus drops and you will hear a few examples of the noise between some tracks. Hear that swish + rumble-type sound?
Is that perfectly acceptable for a modern £325 turntable? Because if it is, I think I need to move up several gears, unless there are known mods I can make to the table to fix this? :'(
So, assuming I screwed the pooch with the Pro-Ject Debut, and with a budget of approx. £1500, please recommend me a good turntable + floorstanding speakers. I already have a 12-year-old Sony integrated amp but if you think I also need a phono pre and new amp then please feel free. I like my music with a mellow mid and sweet highs, and bass I can hear without needing to reglaze. FWIW the floorstanders I was looking at included the Cambridge Aero 6's and the Q Acoustic 2050i's.
