- Aug 10, 2019
- 2,556
- 5
- 0
I am listening to more and more vinyl and have decided that I should consider upgrading my TT in the coming months.
I listen to a vide variety of music generally but probably 75% of the vinyl I buy is jazz so any turntable would have to handle that well. In terms of appearnace I like quite traditional looking turntables and would need a design that either has a lid or could at least have one fitted.
My budget would be up to £1000 and i'd consider 2nd hand if I could hear a demo and pick it up personally. You seem to be able to pick up decent second hand linn sondeks for under £1000 or possibly a new Rega P5 or a higher spec Pro-ject. Anything else i should consider lining up for a demo? Are there any retailers within 100 miles of Manchester that have a particularly good selection of turntables?
