Tray, or slot loading?
Curious:
JohnDuncan:I think slot loading leads to double insertion.
Can you fit 2 in the same hole you mean? That would be bad also.
You rude, rude people. A name like curious does'nt help either ...
Curious:I see Cyrus have slot loading. Which is better? I think slot loading leads to fingerprints.
It saves the space a tray would need and looks better IMHO. Fingerprints could become a problem, however in my experience with the slot loading tray of a macbook, I have no problems whatsoever. I learned you just need a different technique- holding the disc with between thumb (on the outside) and middle finger against the edge of the centre hole, you just shove it in and let go when the slot loader grabs it.
